I’m attaching screengrabs of my before and after. When I import into Lightburn and select Trace Image, I can’t get it to create lines that are like the before as an end result. I’ve tried various settings but I only get rounded trace lines instead of closely aligned. How can I get the end result I need?
This is what i’m getting with defaults…
I can’t seem to recreate your results:
Curious what the image might be.
On a separate note, not sure what your intent is for this but if you want to explore LightBurn this might be a good time to create your own rattan pattern.
Oz illustrates how to do this in a video step by step:
Drawing a rattan weave pattern in LightBurn - YouTube
Thank you for your help. When I import directly, it works fine. Originally I had opened in Affinity Designer and exported. And thank you for the video reference!
