Hi,
I’ve two MacBook Pro’s running same MacOS version and same Lightburn version but behave differently when tracing the same image when using the same settings.
Machine 1, does what I want:
Have the traced image filled completely
Machine 2:
Only have an outline of the traced image and not fill it.
I’ve double checked my settings when tracing, both machine have the same settings:
If needed I’ve a screencast of both machines when traceing the image.
What I’ve tried:
Restart Lightburn
Redownload the image
Switched to Line and back to Fill
Changed color of the layer
I’m out of ideas why machine 2 does a diffrent job on the Trace Image. Maybe I overlooked something? Hope some one can give me some advice.
gilaraujo
(Gil Araújo)
June 23, 2024, 8:48am
2
Hello Sander,
To be certain both Macs have exactly the same settings you can use the Bundle feature to migrate all settings, definitions, and libraries over.
File > bundles > Export on 1 mac
File > bunldes > Import on the 2nd mac.
Seems to me though you have different render behavior
Edit > settings.
Fill Rendering might be selected in one and not the other.
You can also toggle this in the window menu
Thanks! I wasn’t aware of this setting and yes this was the case. Wireframe / Smooth was selected on the Machine 2 and Filled / Smooth on Machine 1…
Also thank you for pointing out how To Sync my settings!
system
(system)
Closed
July 24, 2024, 5:54am
4
