I traced an image in Lightburn. I clicked on “Edit Nodes” which activates but do not show even 1 node on the design. What must I do to see the nodes in order to edit the design? “Close path” & “Convert to path” is greyed out so I cannot even try that. Thank you in advance.
if its multiple shapes together you may have to un-group it.
Thank you it worked, much appreciated.
