Traced image producing double cuts
Hi there! I’m fairly new to this hobby so please bear with me.
I am trying to make rubber stamps with my 10W Algolaser engraver. My designs are in PNG format so I have to use the trace image function to convert it into SVG. The vector comes out fine but when I try to engrave it, it produces ‘double cuts’. I tried engraving it with just 1 pass but the problem still persists.
Here are my parameters:
Speed (mm/sec) - 15.00
Max Power (%) - 50.00
Mode - Offset Fill
Line Interval - 0.0635
Lines per Inch - 400.00
Passes - 3
Ramp Edge - On
I absolutely need to have the offset fill option as it burns the rubber better and produces a cleaner cut than the fill option. Also I need to have several passes to make the engrave deeper. I plan on working with more complex designs than this (star for example purposes only).
Hope someone can help me! Thanks in advance. :slight_smile:
Can you post your .png file?
Sorry I forgot to attach. I just got this off from google but I did try with my own designs. Same results. :confused:
It seems you have some shift (maybe in X) and you first need to make mechanical adjustments. Run the file in the following post and upload a photo of the output.
For shapes like that one you can also use Flood Fill
And for stamps you can also try Ramp option
Hi there. Thank you for the suggestions! I tried engraving the file as per the thread and the pattern did come out wonky which confirmed the mechanical issues. I adjusted the x-axis gantry and belts, ran the file again and seemed to have solved the problem. :slight_smile: Thanks a lot!
And make sure all set screws on pullies and couplers are tight.
