Tracing an image
In order to get a smoother outline on an imported image I have used the ‘Trace’ tool.
As you can see, when I have traced, I have double cutlines. If I cut the image with my laser it follows both of these lines.
Can I delete one of these lines, and if so, which one to obtain the correct size of the object?
Otherwise, is there an adjustment in LightBurn to get just one cutline?
Lightburn traces on both sides of the line. If you need it close to the center of the line, delete one set of shapes that is either on the outside or inside of the line. Then, offset the other shapes approximately 1/2 the thickness of your line.
Thanks for your help. I need to get to know LightBurn much better!
I now have a very useful MP4 file sent by Lightburn help desk describing exactly what to do. Unfortunately I am unable to upload it as the file format is not accepted.
