When I trace in Lightburn, it creates 2 lines very close together. The line it is initially tracing is 0.25mm wide. How do I finish with only one line in Lightburn?
What you are asking for is known as ‘Single-line’ trace, which is not an option at this time. You may be able to delete one of the two line sets generated. Another option, depending on the complexity of the original art, you could add an ‘Offset’ to one of the line sets to add another set of trace lines, splitting the difference. You can then delete the undesired.
Okay, no worries. Thank you for that
