When I import my drawings from Autocad transform to PDF or DXF at Lightburn the drawing became all open, so I can’t fill it, it’s useful to make lines but I need to fill some area, how can I fix that? Thank’s
What version of LightBurn are you using? LightBurn has had some very recent improvements to DXF import.
Alternatively, if the objects are otherwise well-formed you may be able to close the shapes by selecting the shape and going to Edit->Close Path. If there are small gaps you can use Edit->Close Path with Tolerance.
Good day Berain, If I can call you like this, I have version 1.4.04 Also when I click on my drawing and highlight it and click to Edith then the Close Path stay gray not effective, also on my drawings I cannot see any opening even if Lightburn see them,
Sorry to ask again, do you have any suggestions?
Please post both the Autocad and LightBurn files here, so folks can review and advise. Thanks. ![]()
Yes I will tomorrow morning Thank you.
Hi Guy’s I want to reply to you and thank you for your help, I have found the problem, it come from the cad drawing, it have to be group in it prior to use it on the Lightburn program. Thank again.
