what dictates the transversal speeds indicated below? what, if any, optimization and/or configuration settings are available… and where?
I believe in a traversal moves that the controllers max speed are used.
Additionally, in case others come looking at this, for g-code lasers this value can be overridden with the “Fast Whitespace Scan” speed in Device Settings.
thanks for the input. found it for ruida. line shift speed in the vendor settings.
“line shift speed” is how fast it goes when jumping the small y distance to the next raster line. I’m not sure it would apply to jumping to another raster
I believe “idle move speed/accel” are used here instead
thanks. i’ll play around with them a bit
i too am quite confident it’s ‘Idle speed’ what you’re after.
first time i started up this was set way to high for my setup by default and motors drew so much power the controller fainted. after dialling this down everything behaved well.
