Triangle (Right angle)
I use lightburn on a daily basis but never have had the need to draw a triangle.
I have created a triangle using shape properties making the object have 3 sides. My question is this: Is it possible to have a right triangle (hopefully the correct term)? I am making a jig to place under my rotary to level items in the chuck. My thought is to cut some triangles the length of the rotary base with enough lift in them to level the work. So the triangle would really like a shim. My plan is to make one for each type of item.
I would love to be able to create the triangle and it would have a set length off of the right angle. I would then change the height based on how much angle I need. Is it possible to create such a beast and just adjust the height dimension for changes?
