Hello,
I have issue then laser is engraving and in lightburn program air assist is off it still blowing the air. Using pneumatic solenoid. Any help?
Do you have your controller wired to control air?
I don’t. It’s uncommon, from China at least, to have software air assist control, but not hard to implement.
If you already have a solenoid wired into a switch, you can run a separate pair of wires to the air control on the Trocen. That way, you can use your air manual switch to override ‘on’, if you need it. If you have ‘software air’ on, you won’t be able to turn it off with the switch, but will be able to turn it on and off with the switch if you haven’t turned it on in software.
