Trotec Speedy 300c Should I? Ruida Conversion?
Should i gut my 200 hour Trotec 300 electronics? Its immaculate, and make a conversion kit for it?
I only paid $250aud at an auction for this amaxing machine? Yes you heard correct $250 for a speedy 300c with 200 hours. Still like lightburn way better than ruby.
First, make sure it operates. You do not want to discover you bought a $250 cabinet.
Speaking as an electronics guy and not a user/owner, everything I read says gut it. It appears you have a choice of a RuiDa or Trocen controller for Lightburn compatability.
Keep us posted on your progress!
I think it’s working, he’s just asking because he wants to use Lightburn.
You’d only be swapping out the controller, I believe everything should make a smooth transition.
Most of these are the same, sans controller. So it’s not too tough to swap them out. Some differences might be found. One of them is the laser enable signal, the Ruida and the lps expect a low on the L pin (H is the inverted input), whereas some produce a positive enable signal. Some controllers my allow the user to invert the signal. You can look at the lps and see if it’s wired to H or L.
My suggestion is to stick with Ruida.. Some of the newer ones are showing up and I’m sure Lightburn knows about them.
Good luck.
:grinning_cat:
The laser works absolutley perfect, have been usung it for months, like i said only has 200 hours. Like new.
Interesting project.
Following..
Hello,
I modified a Trotec C50, the controller was faulty, and spare parts are no longer available. The issue lies with the servo motors, which require a driver the Leadshine DCS 810 is suitable, but apparently quite difficult to configure correctly. So, I removed the motors and switched to steppers, using parts from a broken Gravograph LS100 I had on hand. It handles 1,500mm/s without any problems. I’m using a Ruida RDC8445S controller with LightBurn over the network it works beautifully.
Greetings from Germany.
Is this an RF machine?
:grinning_cat:
yes, 50w,2x25w
I was wondering about glass tube response time at 1500mm/s, with a metal tube, that speeds probably OK.
I’d suggest replacing it with a Ruida. Whatever settings you can get from the machine will probably help you set it up.
:grinning_cat:
I’ve got a ULS 32x18 I’m converting to a Ruida. This is basically the same frame used in VLS/PLS660, but it’s from a brief period where it was fitted with a Coherent Diamond G100 100W before ULS started rolling their own UL60/ULR60/UL50 etc.
The Coherent is a MUCH better tube.
You do want the datasheet for the tube if you can get it. Like the Diamond G has a max duty cycle and max pulse single width. Exceeding it will cause a blanking interval that would look like something’s wrong with the hardware as the beam output would do wonky things.
That’s the other thing I like about Coherent- I have all the detailed mfg documentation for it. Trotec… I don’t know what’s out there for it, I haven’t seen anything like that for those.
It uses a Synrad Series 48 laser. Trotec systems operate a bit differently than those with Ruida controllers. No extra space is required at the edges of the engraving area; the machine adjusts the laser’s power output during acceleration, ensuring consistent results. Ruida systems, on the other hand, accelerate first and only activate the laser once full speed is reached, meaning the work is always performed at a constant power level and speed. The downside is that high speeds require significant space for acceleration—often a matter of several centimeters.
The high speed has the advantage of producing a very light-colored engraving, even when the cut is relatively deep. I use it for branding wood; it leaves absolutely no scorch marks and looks really good.
All of these machines have overscan as far as I know.
When a machine has to come to a stop, accelerate in the other direction up to speed before it can lase. How fast this can occur is based on physics …
Especially since a glass tube will not go to zero power linearly. Most stop lasing in the ~10% power setting. And in fact they are not linear to begin with. Which is why a glass tube laser is know as negative resistance device, meaning it doesn’t comply with Ohms law.
How is your machine getting around basic physics?
Now you have peaked my curiosity. :face_with_spiral_eyes:
:grinning_cat:
