Trouble with Calibration
Hi Everybody,
I buy an USB camera (Xiaovv 150°) and try to run it with LightBurn 1.6.03
When I go on the tool for the objective calibration, I see my webcam on the list (V380 FHD camera), I select it and see the image (live image is working at this step). I click on “Next” to do the calibration
But here I have a trouble. When I click on “Capture”, nothing happens.
I cover the honeycomb, and even with the dots, it’s the same.
Like the camera is not compatible with Lightburn…
So, no image is taken, no calibration…
Did I miss something ? Should I try something else ? A driver is missing ?
(Sorry for my English, it’s not my mothertongue).
Thanks for your help !
Try to change the camera capture system in main device settings (bottom-left corner in the settings window).
Wonderfull !
It’s working now !
Thanks a lot !
Another question (I take the opportunity to ask):
My camera doesn’t see the entire surface (like 90% of it).
Is it possible to work on the full field but see with the camera only the middle?
What I mean is that my honeycomb is 360x360mm, and the field of view of the camera will be more 400x 300… Is this a problem?
You need to place the camera such that it sees the homing position. Usually bottom-left. You can’t center it. And you can’t use the full workspace while using the camera. Here are some tips about that:
