No, you’re past that. The Bridge is already on your network.
Click next on this screen:
Your Bridge should then appear on the next screen.
If you login into your router can you see that the Bridge is connected? What does your TV look like now?
Not sure how to log into my router. As for the Terminal output:
Last login: Tue Dec 21 12:52:35 on console
The default interactive shell is now zsh.
To update your account to use zsh, please run chsh -s /bin/zsh.
For more details, please visit Use zsh as the default shell on your Mac - Apple Support.
Arthurs-MBP:~ ifconfig
lo0: flags=8049<UP,LOOPBACK,RUNNING,MULTICAST> mtu 16384
options=1203<RXCSUM,TXCSUM,TXSTATUS,SW_TIMESTAMP>
inet 127.0.0.1 netmask 0xff000000
inet6 ::1 prefixlen 128
inet6 fe80::1%lo0 prefixlen 64 scopeid 0x1
nd6 options=201<PERFORMNUD,DAD>
gif0: flags=8010<POINTOPOINT,MULTICAST> mtu 1280
stf0: flags=0<> mtu 1280
en0: flags=8863<UP,BROADCAST,SMART,RUNNING,SIMPLEX,MULTICAST> mtu 1500
options=400<CHANNEL_IO>
ether 78:9f:70:7a:35:9a
inet6 fe80::146a:a72e:a713:60bf%en0 prefixlen 64 secured scopeid 0x4
inet 192.168.1.xxx netmask 0xffffff00 broadcast 192.168.1.xxx
media: autoselect
status: active
en1: flags=8963<UP,BROADCAST,SMART,RUNNING,PROMISC,SIMPLEX,MULTICAST> mtu 1500
options=460<TSO4,TSO6,CHANNEL_IO>
ether 82:0f:1a:7c:a4:40
media: autoselect
status: inactive
en2: flags=8963<UP,BROADCAST,SMART,RUNNING,PROMISC,SIMPLEX,MULTICAST> mtu 1500
ether 82:0f:1a:7c:a4:41
media: autoselect
status: inactive
bridge0: flags=8863<UP,BROADCAST,SMART,RUNNING,SIMPLEX,MULTICAST> mtu 1500
options=63<RXCSUM,TXCSUM,TSO4,TSO6>
Configuration:
id 0:0:0:0:0:0 priority 0 hellotime 0 fwddelay 0
maxage 0 holdcnt 0 proto stp maxaddr 100 timeout 1200
root id 0:0:0:0:0:0 priority 0 ifcost 0 port 0
ipfilter disabled flags 0x0
member: en1 flags=3<LEARNING,DISCOVER>
ifmaxaddr 0 port 5 priority 0 path cost 0
member: en2 flags=3<LEARNING,DISCOVER>
ifmaxaddr 0 port 6 priority 0 path cost 0
media:
status: inactive
p2p0: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> mtu 2304
ether 0a:9f:70:7a:35:9a
media: autoselect
status: inactive
awdl0: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> mtu 1484
ether 7a:12:5e:d7:af:e3
inet6 fe80::7812:5eff:fed7:afe3%awdl0 prefixlen 64 scopeid 0x9
media: autoselect
status: active
llw0: flags=8863<UP,BROADCAST,SMART,RUNNING,SIMPLEX,MULTICAST> mtu 1500
inet6 fe80::7812:5eff:fed7:afe3%llw0 prefixlen 64 scopeid 0xa
media: autoselect
status: active
utun0: flags=8051<UP,POINTOPOINT,RUNNING,MULTICAST> mtu 1380
inet6 fe80::a4c8:9a3f:ea0f:383c%utun0 prefixlen 64 scopeid 0xb
utun1: flags=8051<UP,POINTOPOINT,RUNNING,MULTICAST> mtu 2000
inet6 fe80::68a8:53a4:7d17:1b85%utun1 prefixlen 64 scopeid 0xc
utun2: flags=8051<UP,POINTOPOINT,RUNNING,MULTICAST> mtu 1380
inet6 fe80::738b:3697:65bb:ec15%utun2 prefixlen 64 scopeid 0xd
utun3: flags=8051<UP,POINTOPOINT,RUNNING,MULTICAST> mtu 1380
inet6 fe80::5ebd:82ff:7dca:2fdc%utun3 prefixlen 64 scopeid 0xe
en4: flags=8863<UP,BROADCAST,SMART,RUNNING,SIMPLEX,MULTICAST> mtu 1500
ether 32:57:14:51:9e:be
inet6 fe80::1c2e:e79b:4088:8c2a%en4 prefixlen 64 secured scopeid 0xf
inet 169.254.247.13 netmask 0xffff0000 broadcast 169.254.255.xxx
media: autoselect (100baseTX )
status: active
Last login: Fri Jan 14 22:18:33 on console
Restored session: Fri Jan 14 22:16:35 EST 2022
ping 192.168.1.36
PING 192.168.1.36 (192.168.1.36): 56 data bytes
64 bytes from 192.168.1.36: icmp_seq=0 ttl=64 time=52.016 ms
64 bytes from 192.168.1.36: icmp_seq=1 ttl=64 time=3.101 ms
64 bytes from 192.168.1.36: icmp_seq=2 ttl=64 time=4.172 ms
64 bytes from 192.168.1.36: icmp_seq=3 ttl=64 time=4.482 ms
64 bytes from 192.168.1.36: icmp_seq=4 ttl=64 time=4.310 ms
64 bytes from 192.168.1.36: icmp_seq=5 ttl=64 time=5.795 ms
64 bytes from 192.168.1.36: icmp_seq=6 ttl=64 time=5.193 ms
64 bytes from 192.168.1.36: icmp_seq=7 ttl=64 time=3.571 ms
64 bytes from 192.168.1.36: icmp_seq=8 ttl=64 time=3.133 ms
64 bytes from 192.168.1.36: icmp_seq=9 ttl=64 time=3.566 ms
64 bytes from 192.168.1.36: icmp_seq=10 ttl=64 time=4.184 ms
64 bytes from 192.168.1.36: icmp_seq=11 ttl=64 time=3.107 ms
64 bytes from 192.168.1.36: icmp_seq=12 ttl=64 time=6.590 ms
64 bytes from 192.168.1.36: icmp_seq=13 ttl=64 time=4.761 ms
64 bytes from 192.168.1.36: icmp_seq=14 ttl=64 time=301.163 ms
64 bytes from 192.168.1.36: icmp_seq=15 ttl=64 time=3.530 ms
64 bytes from 192.168.1.36: icmp_seq=16 ttl=64 time=5.254 ms
64 bytes from 192.168.1.36: icmp_seq=17 ttl=64 time=4.201 ms
64 bytes from 192.168.1.36: icmp_seq=18 ttl=64 time=3.988 ms
64 bytes from 192.168.1.36: icmp_seq=19 ttl=64 time=4.592 ms
64 bytes from 192.168.1.36: icmp_seq=20 ttl=64 time=3.341 ms
64 bytes from 192.168.1.36: icmp_seq=21 ttl=64 time=4.667 ms
64 bytes from 192.168.1.36: icmp_seq=22 ttl=64 time=3.197 ms
64 bytes from 192.168.1.36: icmp_seq=23 ttl=64 time=3.247 ms
64 bytes from 192.168.1.36: icmp_seq=24 ttl=64 time=3.258 ms
64 bytes from 192.168.1.36: icmp_seq=25 ttl=64 time=4.631 ms
64 bytes from 192.168.1.36: icmp_seq=26 ttl=64 time=3.343 ms
64 bytes from 192.168.1.36: icmp_seq=27 ttl=64 time=4.755 ms
64 bytes from 192.168.1.36: icmp_seq=28 ttl=64 time=4.922 ms
64 bytes from 192.168.1.36: icmp_seq=29 ttl=64 time=2.894 ms
64 bytes from 192.168.1.36: icmp_seq=30 ttl=64 time=4.103 ms
64 bytes from 192.168.1.36: icmp_seq=31 ttl=64 time=3.856 ms
64 bytes from 192.168.1.36: icmp_seq=32 ttl=64 time=4.149 ms
64 bytes from 192.168.1.36: icmp_seq=33 ttl=64 time=4.216 ms
64 bytes from 192.168.1.36: icmp_seq=34 ttl=64 time=4.221 ms
64 bytes from 192.168.1.36: icmp_seq=35 ttl=64 time=3.233 ms
64 bytes from 192.168.1.36: icmp_seq=36 ttl=64 time=3.915 ms
64 bytes from 192.168.1.36: icmp_seq=37 ttl=64 time=3.521 ms
64 bytes from 192.168.1.36: icmp_seq=38 ttl=64 time=4.362 ms
64 bytes from 192.168.1.36: icmp_seq=39 ttl=64 time=4.396 ms
64 bytes from 192.168.1.36: icmp_seq=40 ttl=64 time=2.310 ms
64 bytes from 192.168.1.36: icmp_seq=41 ttl=64 time=3.870 ms
64 bytes from 192.168.1.36: icmp_seq=42 ttl=64 time=2.665 ms
64 bytes from 192.168.1.36: icmp_seq=43 ttl=64 time=6.351 ms
64 bytes from 192.168.1.36: icmp_seq=44 ttl=64 time=51.567 ms
64 bytes from 192.168.1.36: icmp_seq=45 ttl=64 time=5.221 ms
64 bytes from 192.168.1.36: icmp_seq=46 ttl=64 time=6.247 ms
64 bytes from 192.168.1.36: icmp_seq=47 ttl=64 time=4.535 ms
64 bytes from 192.168.1.36: icmp_seq=48 ttl=64 time=3.219 ms
64 bytes from 192.168.1.36: icmp_seq=49 ttl=64 time=3.147 ms
64 bytes from 192.168.1.36: icmp_seq=50 ttl=64 time=3.761 ms
64 bytes from 192.168.1.36: icmp_seq=51 ttl=64 time=3.090 ms
64 bytes from 192.168.1.36: icmp_seq=52 ttl=64 time=3.777 ms
64 bytes from 192.168.1.36: icmp_seq=53 ttl=64 time=3.256 ms
64 bytes from 192.168.1.36: icmp_seq=54 ttl=64 time=19.910 ms
64 bytes from 192.168.1.36: icmp_seq=55 ttl=64 time=6.968 ms
64 bytes from 192.168.1.36: icmp_seq=56 ttl=64 time=6.018 ms
64 bytes from 192.168.1.36: icmp_seq=57 ttl=64 time=4.731 ms
64 bytes from 192.168.1.36: icmp_seq=58 ttl=64 time=3.363 ms
64 bytes from 192.168.1.36: icmp_seq=59 ttl=64 time=4.945 ms
64 bytes from 192.168.1.36: icmp_seq=60 ttl=64 time=3.345 ms
64 bytes from 192.168.1.36: icmp_seq=61 ttl=64 time=3.777 ms
64 bytes from 192.168.1.36: icmp_seq=62 ttl=64 time=8.390 ms
64 bytes from 192.168.1.36: icmp_seq=63 ttl=64 time=3.103 ms
64 bytes from 192.168.1.36: icmp_seq=64 ttl=64 time=3.858 ms
64 bytes from 192.168.1.36: icmp_seq=65 ttl=64 time=4.689 ms
64 bytes from 192.168.1.36: icmp_seq=66 ttl=64 time=3.063 ms
64 bytes from 192.168.1.36: icmp_seq=67 ttl=64 time=6.625 ms
64 bytes from 192.168.1.36: icmp_seq=68 ttl=64 time=3.789 ms
64 bytes from 192.168.1.36: icmp_seq=69 ttl=64 time=3.445 ms
64 bytes from 192.168.1.36: icmp_seq=70 ttl=64 time=3.502 ms
64 bytes from 192.168.1.36: icmp_seq=71 ttl=64 time=3.726 ms
64 bytes from 192.168.1.36: icmp_seq=72 ttl=64 time=7.365 ms
64 bytes from 192.168.1.36: icmp_seq=73 ttl=64 time=3.346 ms
64 bytes from 192.168.1.36: icmp_seq=74 ttl=64 time=4.403 ms
64 bytes from 192.168.1.36: icmp_seq=75 ttl=64 time=3.635 ms
64 bytes from 192.168.1.36: icmp_seq=76 ttl=64 time=3.161 ms
64 bytes from 192.168.1.36: icmp_seq=77 ttl=64 time=8.185 ms
64 bytes from 192.168.1.36: icmp_seq=78 ttl=64 time=3.749 ms
64 bytes from 192.168.1.36: icmp_seq=79 ttl=64 time=3.838 ms
64 bytes from 192.168.1.36: icmp_seq=80 ttl=64 time=3.230 ms
64 bytes from 192.168.1.36: icmp_seq=81 ttl=64 time=4.209 ms
64 bytes from 192.168.1.36: icmp_seq=82 ttl=64 time=10.165 ms
@adammhaile Any insight on this? Can’t see why the Bridge wouldn’t show up in the device scan.
Could be a local network config thing… but honestly unsure. My advice would be to skip the scan, manually create a Ruida device and just choose Bridge as the connection option and manually input the IP address. And see if it still won’t connect.
The scan usually works, but it’s not infallible.
That did the trick. I deleted the existing device and started from scratch using the manual option. Looks like we’re in business. Thanks for the assist, gents.
