HI All
Im having ‘Trouble with scrolling while typing’. I get 10 lines down and my typing disapears behind the keyboard on my phone screen.
I have not had an issue like this previously…Any advice?
HI All
Please show us what you are seeing. Where are you typing? In LightBurn? On the Forum? It is not clear from your wording. ![]()
I think when writing a post, the text does not “scroll”, i.e. at some point the last line of text can no longer be seen. This is what I experience on iOS devices. Unfortunately I think it is an OS related problem, because the same issues also occur (for me) when using Google Translate. The keyboard fills half the screen and the current text does not scroll up as it should, i.e. the last line disappears under the keyboard at some point, very annoying, but not something LB can/should be blamed for.
Thanks for getting back on this one. It happened while answering a post here on LBf but I dont use other forums etc so thought it might be LB related as all was normal earlier today. I’ll try txt and email and check settings even though no changes have been made that I’m aware of.
Hang On!! I just pressed on a button at top of the page ( Two inverted chevrons) that brought me back to this Topic page, I then pressed a blue Notification bar at bottom of phone screen related to this reply..that re-opened this reply… I pressed the Return key a bunch of times and now it is scrolling again.
Thanks for your kind attention.
