TRY TO CONNECT OLM CARD ("OLM-ESP-PRO_V1.2a")
Hello! I try to connect this card on a big working laser area (100cm x100cm).
I just have this picture on the web
This is an Aufero laser v2 with 3 motors and the board is the same as OLM S2 pro. I need to know how connecting the Y1 and Y2 motors on board. If someone can disassembly an Aufero v2 system for see the wiring: it can be so cool.
If you have any questions…
Thanks a lot in advance for your responses!
Just wondering if you could tell me what kind of connectors they have used on the board.
I want to hook up my enclosure fan and lights to the board, as well as adding limit switches.
The 2x9 and 2x3 connectors for that seem similar, but I can’t seem to find which counterpart I need to buy that will actually fit.
Seems from your picture that you found something that fits, so I’d love to know the type of that connector.
Thanks!
You might want to contact Ihab. He makes cables for Ortur machines, here is a link to his Etsy page:
Ortur Laser Cable Replacements Stock, Drag Chain, Extended Frames for the LM2, Pro S1 S2, LM2 S2, and Rotary please Read Description - Etsy
He may have a source for those connectors.
