I hae an image ( a string of Holly about 120mm long x 10mm high wgich I want to bend it around a corner. Is there any way to do this in ligtburn?
Check out the Warp and Deform tools:
Len, are you working with a raster (image) or a vector (object)?
AFAIK, you cannot manipulate an image in that fashion. Your best approach will be to TRACE the image to create a vector object. The. You can warp and deform and you can selectively copy and paste or even node edit to reach your goal.
Please upload your work file example, so the forum gurus can better understand what your are working with and toward.
Warp and Deform both work with images in addition to vector objects. ![]()
Thank you for the reminder
