Trying to burn a imported picture
I am new to light burn and I can not figure out what steps I need to perform in order to burn a photo I have imported into the light burn software. I am able to burn text that I type in with the software. But I can’t get a picture to show up in the preview window.
If you haven’t changed any of the default settings for images, you should be able to just import a picture and click Preview. If you zoom in, you’ll see detail.
I am doing an import off a JPG file which comes in very large so I size it smaller to be able to see the whole picture. then i click on the preview screen and there is nothing, Is there a scan option I should be doing to get the image into the preview? I have not changed any preview options that i am aware off.
You probably haven’t made it small enough to fit within your work area, and if that’s the case, LightBurn defaults to discarding anything that won’t actually run properly on the laser. Make it the size you would burn it at, not just small enough to fit it view.
I finally figured it out, i set the size percent to 50% and it fit int the work area and was available to preview. Thanks for all your help and have a great day!
