Trying to connect 2nd laser to Lightburn - adding fiber laser
I already have Lightburn installed for my Co2 laser and I just got a Fiber laser and want to download EZCad for Lightburn. I’m not sure if I’ve added my laser properly because I already had Lightburn installed. My fiber laser shows disconnected even when it’s own and the usb is plugged in.
EZCad comes from the Chinese JCZ people for the controller… It is not related to Lightburn… I doubt the fiber and your other laser use the same driver, but it should work.
It’s likely that you don’t have the proper driver for windows installed. Using Windows the EZCad driver and Lightburn driver are not compatible.
Laser Everything also has a set of settings they give away. As a new user, you might want to head over there and see what you can see…
Good luck
