Trying to cut. Laser doesn't stop between shapes
The first image is the traced image used and the second is the result. As you can see the laser doen’t stop between cuts and it cut its trajectory on the paperboard.
I m using line with speed power 6000/80 2 passes with optimize cut path.
Without wanting to be rude, I will direct you to seek the solution of your problem in the search box, here on the page, top right Your question has to do with the settings of your laser and is asked very often. Depending on your laser, you are guaranteed to find the right solution in the archive.
