Trying to engrave only the names , background water, nautical compass, and nautical co-ordinates
The bottom image is the original file.
the middle image is what I am looking to achieve.
No matter inverted or not, the top image is what is being created.
Can anyone help me?
Create a rectangle around the whole image on the same layer. This inverts the inside.
I thought this was an image file and that box around it only worked with fill? There is an option in the cut/layer editor that allows you to invert an image…
I think he needs to find a vector file, if possible, it would be much more simple than his posted screen shot.
If it is a vector, then @misken is correct…
Thank you all !!! @misken is correct worked perfectly!
