I am super new to lightburn. I’m trying to engrave coasters.
For some reason it’s filling the ones on the left.
No open paths that it tells me.
Would you mind uploading the .lbrn file for review?
If you zoom in closely to the flowers on the left you can see that there is no outline shape… just a solid shape for each petal. This is why they are showing as filled.
Easiest remedy is likely to select the flower, then use Offset Shapes with “outer shapes only” enabled to create a thin outer line around the shape. This will then form a line between the old boundary and the new offset.
thank you so much!!!
