Trying to frame object
Having problems framing an object and I keep getting this message on the machine control panel. I am using a Longer Ray 5 20 watt.
G-code motion target exceeds machine travel. Machine position safely retained. Alarm may be unlocked. (Right-click the ‘Devices’ button to reset the connection)
On or near line 0:
ALARM:2
Suggest review of the following. :slight_smile:
A few questions:
What Job Origin are you using?
Did you create your Laser device manually? And is correctly set?
Type $$ into Console Window and post back the output.
