Hi All,
I am attempting to set up my original laser engraver to the same PC as my xTool is on. However, this laser is a GRBL and the GRBL program is on a disabled PC. Disabled meaning the keyboard letters do not work, just the number pad does and the power cuts out, likely due to a bad battery, (I’m guessing). Question is if anyone knows how I might retrieve or otherwise get the GRBL program needed for this. I will continue to seek out a fix, but any advise is always appreciated.
Thanks a bunch!
Keith
Lightburn can use any controller, all have the default controller language, grbl.
You should have three seats for the software… You can go to the license portal and remove the one on the bad pc…
Thanks Jack. So what you are saying is that xTool also has the controller language grbl? I’ll give it a try and reach out again if I hit a snag. As always, thanks.
