TT-20 Pro ALARM:2 G-code motion target exceeds machine travel
ALARM:2
G-code motion target exceeds machine travel. Machine position safely retained. Alarm may be unlocked. (Right-click the ‘Devices’ button to reset the connection)
On or near line 0:
Job halted
I have tried Soooo many options for this , it has worked only once when i first got it , and now Nothing, I have tried to change $10=1 to $10=0
not sure I’ve even done that right since nothing has changed, I’d really like to use the Machine i’m thinking it’s out of date
Also
ALARM:9
Homing fail. Could not find limit switch within search distance. Defined as 1.5 * max_travel on search and 5 * pulloff on locate phases.
ok
Grbl 1.1h [‘$’ for help]
ok
[MSG:‘$H’|‘$X’ to unlock]
ok
[MSG:Caution: Unlocked]
ok
Hi Tre,
Alarm 2 are for the most part issue based on coordinates.
a) What Start from have you selected. Absolute coordinates?
b) in console type
press ente
press enter
Send output please.
yes i have before
$54=12345678
$53=MKS_DLC
$52=12345678
$51=Laser_
$0=10
$1=25
$2=0
$3=5
$4=0
$5=1
$6=0
$10=1
$11=0.010
$12=0.002
$13=0
$20=1
$21=1
$22=1
$23=5
$24=25.000
$25=500.000
$26=250.000
$27=1.000
$28=1000.000
$30=1000.000
$31=0.000
$32=1
$41=1
$47=1
$46=1
$102=100
$101=180.000000
$45=0
$44=1
$43=1
$42=1
$50=1
$40=1
$100=120.000
$103=100.000
$104=100.000
$105=100.000
$110=30000.000
$111=30000.000
$112=6000.000
$113=1000.000
$114=1000.000
$115=1000.000
$120=2500.000
$121=2500.000
$122=500.000
$123=200.000
$124=200.000
$125=200.000
$130=301.000
$131=301.000
$132=50.000
$133=300.000
$134=300.000
$135=300.000
ok
[G54:0.000,0.000,0.000]
[G55:0.000,0.000,0.000]
[G56:0.000,0.000,0.000]
[G57:0.000,0.000,0.000]
[G58:0.000,0.000,0.000]
[G59:0.000,0.000,0.000]
[G28:0.000,0.000,0.000]
[G30:0.000,0.000,0.000]
[G92:0.000,0.000,0.000]
[TLO:0.000]
[PRB:0.000,0.000,0.000:0]
ok
Either X or Y are incorrect on steps per mm
Isyour TTS only 300x300?
I would suggest a firmware reset
$RST=*
Press enter
ok i’ll try the reset, I also think i’m not changing the settings correctly, since i have not seen the $10=1 change at all
Are you seeeking to have your steppers to “HOLD”?
If so $1=255 in console.
You can also change them on EDIT > Machine settings.
Just dont forget to write.
$RST=*
[MSG:WiFi reset done]
[MSG:Settings reset done]
[MSG:Position offsets reset done]
ok
Ok now power cycle the machine, off > On
What Start From are you using, absolute coordenates?
My apologies as I am very new , and i’m not sure what (steppers are ) but i do get the same errors over and over
Its ok! :slight_smile:
Stepper are the motors that move your machine
If you post a screenshot of LightBurn, what we want to check is:
In the laser panel, below “START” button. theres a “start from”: dropdown.
What setting is there. Absolute coordinates?
yes as of right now it will be on absolute coordinates
OK great,
Now open this file and just try to engrave it on a little bit of cardboard or spare wood
Dot Test with Angle.lbrn (46.3 KB)
If possible, post a picture of the output
i’m here now , with these new settings,
[MSG:Local access point Laser_53289 started, 192.168.4.1]
[MSG:HTTP Started]
[MSG:TELNET Started 8080]
ok
ok
[V4.00(8M.H35.20231120)]
[VER:1.1h.2023112002:]
[OPT:VMPH,63,256]
Target buffer size found
[MSG:Using machine:MKS DLC32]
ok
[MSG:Mode=STA:SSID=:Status=Not connected:IP=0.0.0.0:MAC=84-FC-E6-7C-29-D0]
[MSG:Mode=AP:SSDI=Laser_53289:IP=192.168.4.1:MAC=86-FC-E6-7C-29-D0]
ok
should i try the file with these settings, and my laser is positioned to the back left corner
I am not sure where the TTS homes, but usually is front/left.
Where are your switches located?
And yes you can start the test file without changing the settings for power/Speed
I don’t have any homing switches , this Machine didn’t come with any but I was thinking about ordering them
Project loaded in 2 milliseconds
Starting stream
Job halted
Stream completed in 0:00
You will have to tell me what the machine did.
Stoped withotu even trying to move?
correct it didn’t move at all , but no errors this time :slight_smile:
Well thats not good!
Unplug the laser head cable if you can, just so we test only motions.
Repeat the run. Same behavior?
