Tts10w laser stoping\freezing during cutting or framing
the laser simply stopped during a job, and now it started to stop in the middle of cutting or engraving and even framing.
I already reduced the power/velo and i also put it to work with the diode pluged off, yet it stopped in the same place.
When it stops, the laser freezes and stops responding and only comes back when I turn it off and on.
Sometimes even turning it off and on, it doesn’t reconnect or it comes back on and locks in the same place.
I already had messages on the console like:
“[MSG:‘$H’|‘$X’ to unlock] [MSG:Caution: Unlocked] ok”
“alarm 3”
“MSG:Restoring spindle”
“lightburn E (94531) gpio: gpio_isr_handler_remove(480): GPIO isr service is not installed, call gpio_install_isr_service() first”
“!�N�-R�� ��� j�h�!�����C��Fï”
console.txt (17,4,KB)
fantasma.gc (48,3,KB)
video links:
From what I have read in the forum, any of the cloud storages used as the program source for Lightburn have problems. Try copying the LB file to your local machine and run it from there.
