Tumbler setup problem
Need a little help,trying to get my OMTech Polar Plus to engrave tumblers,it will frame and when I press go the laser takes a exit stage right and I get a Y axis overscale message what am I doing wrong or did I miss something in the setup.Thnaks Dean
It sounds like you have 2 issues here, origin and Y position. In order to best help you, post a screenshot of your entire Lightburn screen (not a cell pic) with the project loaded, the laser window and move window visible. Click get position in the move window before taking the screenshot. Also post a pic of your rotary in place in your laser bed.
Ok thanks for getting back to me,I updated LB from 1.7.04 to 08 last night and shut down the laser and turned off power to it overnight and now it is working except when in current position it is reversed,in other words if I set it to left center and hit frame it goes to the right if I set it to right center it goes to left I also had a similar issue a few weeks ago where the Yaxis was reversed had to get OMTech involved with that one it has been ok since this is the first I tryed the rotator..
