Turning the laser on in LightBurn
OK, new at this so if this is a stupid question please be gentle. I have a Chinese BenBox Laser. The software that came with it is not very good. I loaded LightBurn, Got it recognize using GRBL-LPC. I can get the machine to run but the laser does not come on. Is there a button on LightBurn that will turn the laser on?
The ā€œChinese BenBox Laserā€ will not run with GRBL-LPC. If you try to stream anything it’ll overload the buffer. Try using ā€˜GRBL-M3’.
Have you flashed your board with grbl? What version? If you have flashed with latest grbl, select ā€˜GRBL’ in devices.
Thanks for the quick answer. The primary reason I purchased this is that I want to create portraits with grayscale. I know that lazor engravers can do that but I figured how to do it. I’ll flash new firmware tomorrow and see what happens.
Boy, I must have been asleep when I wrote that reply. LASER!
Rick, could you point me in the right direction to get the GRBL firmware and brief instructions on how to do it? I don’t want to screw up my controller.
Thanks
Sorry but not really John. I know very little about your system or how to get that sorted. I would be starting as you are. Maybe someone else might chime in here or you could ask in one of the support groups for your BenBox setup.
I think you’ve misunderstood. You don’t need to change the firmware on your controller, you just change the setting in Lightburn from grbl-plc to grbl-m3
No, I did understand but I’m not sure what the firmware is on this machine. grbl-m3 doesn’t work. I can’t get it to link to the board.
Is there a way to determine what the firmware is on this board.
BenBox is not supported but you could try entering ā€œ$$ā€ into he console to see if it returns useful information but it is just a guess on my part.
If you can flash with latest grbl then use the ā€œGRBLā€ device.
John, this might be helpful in your journey.
