Two copies with different settings
Hi!
I am going to use LB with two very different machines, on the same computer.
Can I install two instances of LB with different settings, or a “fast” way to switch between them?
(I export as GCode to burn offline)
No need to have two installations of LightBurn in this case. Simply create another device within LightBurn by pushing the “Devices” button in Laser window.
Select the device to use with the pulldown field in the same Laser window.
