Can I have two laser on this program and use them both at the same time
You can have as many Device Profiles defined as you’d like. LightBurn will only talk to one laser at a time. ‘Save’ will send the entire job as a named file to the controller in one go, while ‘Send’ will stream the job.
You can send a job, switch to another profile, then start to prepare the next job, but LightBurn needs to complete sending the job, so the way you choose matters.
