I have a diode laser and g code lightburn. I have purchased a second, co2 laser with a ruida controller. How do I set lighterburn up to recognize both/either lasers?
You will need to generate another Device Profile for this new CO2 system. Start by using the ‘Find my Laser’ feature to discover your new gear. We have tutorials in the documentation to assist.
You may need to add this profile manually, following this:
Once you have this profile defined and working as you’d expect, you can simply change the system you plan to output too and go!
Thank you!
