Two Software questions: 1: Art Libraries 2) How to manipulate text
1: How to add Art Libraries: I have some Art libraries I would like to add but not sure how.
  1. How to manipulate text closer together for welding: I have tried different ways to ungroup text to be able to manipulate so I can weld without success.
Sorry it has been a couple of years since I have used lightburn.
Thank you
Have a great Thanksgiving
The libraries can be opened in the library window.
Once you converted the font to paths, you can join/weld them. But not all at once usually, because there are ambiguities depending on the letters. Do one at a time.
Thank you. I guess I should have said how to import into the library.
Probably best you take a look at the documentation for Art Library, and view the walkthrough video at the top of the page: Art Library - LightBurn Documentation
I have a few art libraries in .LBART format. Is there a way to convert to current Lightburn compatible format?
When I tried to use “Load” it recognizes the files but it does not import.
Thank you.
Looking at the size of that file leads me to believe the file may be corrupted. I would look for a backup of that original to see if you can recover the contents. :slight_smile:
