Hello,
İ bought two trees tts55 since 20 days and engraved some Woods. Today i have a problem. The machine dont want to engrave anythink. I see the laser (bleu light) works but like a wery low power. I use same parameters i used several days. I have 100% for engraving power bit it works like 10% 20% power output. I tried lasergrbl too but same result. I tried to clean lens of laser anythink changed. Someone can help me plz. I dont understand what is the problem.
If you’re not using an air compressor for air-assist to keep smoke and wood sap off the lens, it may have become dirty over the last 20 days. Different wood behaves differently so there are many unknowns here.
You may want to refer to the manufacturers’ guidelines on cleaning the lens.
