I have a TwoTrees TS2 Laser engraver and use LightBurn V1.1.04.
In many cases, the laser don’t start to work. When I am pressing the „play“ button, the engraver makes a small jerk and the timer is running. But the engraver stay at home position. When I try to move with the buttons in „Movements“ menu the engraver will start a movement. That’s not normal. The problem does not always occur either. I have already engraved quite a bit with it. Sometime it works, but often not.
Two questions: how long have you had it and when did the problem start? If you haven’t already done so, I’d check all your wiring connections. I wasn’t quite clear about “movements”, are you able to jog the laser around the work area without issue or is there a problem there as well?
