TwoTrees TTS-55 Connection Issues with Lighburn GRBL
Hello Guys,
i’am new in the laser business and i’m trying to connect my Two Trees TTS-55 with the Lighburn Software, but it is’nt successful.
I’m getting this out of the console, but i don’t know what that means:
Waiting for connection…
[MSG:Local access point Laser_ started, 192.168.4.1]
[MSG:HTTP Started]
[MSG:TELNET Started 8080]
[MSG:‘$H’|‘$X’ to unlock]
Grbl 1.1 [‘$’ for help]
Your Grbl may not support Variable Power mode (M4)
If your laser does not turn off between cuts,
switch to the GRBL-M3 device
[MSG:Caution: Unlocked]
124
load:0x40080400,len:5856
entry 0x400806a8
When i connect the Laser with LaserGRBL everything works fine. The Baudrate is set to 115200 and thats the same as in LaserGRBL.
There is a .lbset with configuration for the TTS, but i dont know how to load it.
Is there anybody who can help me?
Thanks a lot.
To me the output looks more like a firmware issue, but then LaserGRBL also shouldn’t be able to connect successfully. Can you move the laser using LaserGRBL?
While tackling another problem, we found a solution to change the “enable DTR signal” option in device settings to make the connection work properly. You might try this as well.
I can move the laser with LaserGRBL properly and homing is also working fine with my self added limit switches in LaserGRBL
Thanks Melvin!
I enabled DTR and now its working!
