I know this has been covered, but it appears I might have something else going on. Lightburn doesn’t detect the USB device. I’ve entered the “sudo adduser $USER dialout && sudo adduser $USER tty” command, logged out, rebooted, tried everything I can think of. The OS does see the device:
[ 2558.598123] usb 1-1.2: new high-speed USB device number 12 using xhci_hcd
[ 2558.786568] usb 1-1.2: New USB device found, idVendor=9588, idProduct=9899, bcdDevice= 0.00
[ 2558.786571] usb 1-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 2558.786572] usb 1-1.2: Product: USBLMCV2
[ 2558.786573] usb 1-1.2: Manufacturer: BJJCZ
[ 2558.786574] usb 1-1.2: SerialNumber
And to verify that it wasn’t cables or the laser, I set it up on my mac, and I could use the laser.
Thank you for your help.
It’s Ubuntu 22.04.1 - just installed today. Running on a system76 meerkat with 32G RAM
Joe
Can you check if a serial device has been created?
ls -l /dev/*USB*
Also, can you run these commands to get some more information:
lsusb
lsusb -t
sudo dmesg | grep -i "1-1"
sudo ls -l /dev/USB
[sudo] password for sara:
ls: cannot access ‘/dev/USB’: No such file or directory
I guess a serial device wasn’t created (tried without sudo first)
sara@em-76:~$ lsusb
Bus 004 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 002 Device 004: ID 3384:7216 System76 USB7216 Smart Hub
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 002: ID 046d:c52b Logitech, Inc. Unifying Receiver
Bus 001 Device 004: ID 8087:0026 Intel Corp. AX201 Bluetooth
Bus 001 Device 011: ID 3384:0001 System76 Launch Configurable Keyboard (launch_1)
Bus 001 Device 013: ID 9588:9899 BJJCZ USBLMCV2
Bus 001 Device 010: ID 3384:4216 System76 USB4216 Smart Hub
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
sara@em-76:~$ lsusb -t
/: Bus 04.Port 1: Dev 1, Class=root_hub, Driver=xhci_hcd/2p, 10000M
/: Bus 03.Port 1: Dev 1, Class=root_hub, Driver=xhci_hcd/2p, 480M
/: Bus 02.Port 1: Dev 1, Class=root_hub, Driver=xhci_hcd/6p, 10000M
|__ Port 1: Dev 4, If 0, Class=Hub, Driver=hub/4p, 10000M
/: Bus 01.Port 1: Dev 1, Class=root_hub, Driver=xhci_hcd/12p, 480M
|__ Port 1: Dev 10, If 0, Class=Hub, Driver=hub/5p, 480M
|__ Port 5: Dev 11, If 2, Class=Human Interface Device, Driver=usbhid, 12M
|__ Port 5: Dev 11, If 0, Class=Human Interface Device, Driver=usbhid, 12M
|__ Port 5: Dev 11, If 1, Class=Human Interface Device, Driver=usbhid, 12M
|__ Port 2: Dev 13, If 0, Class=Vendor Specific Class, Driver=, 480M
|__ Port 2: Dev 2, If 2, Class=Human Interface Device, Driver=usbhid, 12M
|__ Port 2: Dev 2, If 0, Class=Human Interface Device, Driver=usbhid, 12M
|__ Port 2: Dev 2, If 1, Class=Human Interface Device, Driver=usbhid, 12M
|__ Port 10: Dev 4, If 0, Class=Wireless, Driver=btusb, 12M
|__ Port 10: Dev 4, If 1, Class=Wireless, Driver=btusb, 12M
sara@em-76:~$ sudo dmesg | grep -i “1-1”
[ 0.000000] microcode: microcode updated early to revision 0xf0, date = 2021-11-17
[ 0.297623] PM: RTC time: 18:23:43, date: 2023-01-19
[ 0.660950] rtc_cmos rtc_cmos: setting system clock to 2023-01-19T18:23:44 UTC (1674152624)
[ 2.181241] usb 1-10: new full-speed USB device number 4 using xhci_hcd
[ 2.330870] usb 1-10: New USB device found, idVendor=8087, idProduct=0026, bcdDevice= 0.02
[ 2.330883] usb 1-10: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 21.969158] usb 1-1: new high-speed USB device number 6 using xhci_hcd
[ 22.189617] usb 1-1: New USB device found, idVendor=9588, idProduct=9899, bcdDevice= 0.00
[ 22.189622] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 22.189623] usb 1-1: Product: USBLMCV2
[ 22.189624] usb 1-1: Manufacturer: BJJCZ
[ 22.189625] usb 1-1: SerialNumber: 20120331001
[ 92.117419] usb 1-1: USB disconnect, device number 6
[ 259.961830] usb 1-1: new high-speed USB device number 7 using xhci_hcd
[ 260.132245] usb 1-1: New USB device found, idVendor=3384, idProduct=4216, bcdDevice= 6.22
[ 260.132249] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 260.132250] usb 1-1: Product: USB4216 Smart Hub
[ 260.132251] usb 1-1: Manufacturer: Microchip
[ 260.132882] hub 1-1:1.0: USB hub found
[ 260.132916] hub 1-1:1.0: 5 ports detected
[ 260.425886] usb 1-1.5: new full-speed USB device number 8 using xhci_hcd
[ 260.528543] usb 1-1.5: New USB device found, idVendor=3384, idProduct=0001, bcdDevice= 0.01
[ 260.528547] usb 1-1.5: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 260.528548] usb 1-1.5: Product: Launch Configurable Keyboard (launch_1)
[ 260.528549] usb 1-1.5: Manufacturer: System76
[ 260.539050] input: System76 Launch Configurable Keyboard (launch_1) as /devices/pci0000:00/0000:00:14.0/usb1/1-1/1-1.5/1-1.5:1.0/0003:3384:0001.0008/input/input23
[ 260.600220] input: System76 Launch Configurable Keyboard (launch_1) System Control as /devices/pci0000:00/0000:00:14.0/usb1/1-1/1-1.5/1-1.5:1.2/0003:3384:0001.000A/input/input24
[ 260.657794] input: System76 Launch Configurable Keyboard (launch_1) Consumer Control as /devices/pci0000:00/0000:00:14.0/usb1/1-1/1-1.5/1-1.5:1.2/0003:3384:0001.000A/input/input25
[ 260.657924] input: System76 Launch Configurable Keyboard (launch_1) Keyboard as /devices/pci0000:00/0000:00:14.0/usb1/1-1/1-1.5/1-1.5:1.2/0003:3384:0001.000A/input/input26
[ 2497.392064] usb 1-1: USB disconnect, device number 7
[ 2497.392068] usb 1-1.5: USB disconnect, device number 8
[ 2532.035537] usb 1-1: new high-speed USB device number 10 using xhci_hcd
[ 2532.200814] usb 1-1: New USB device found, idVendor=3384, idProduct=4216, bcdDevice= 6.22
[ 2532.200827] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 2532.200832] usb 1-1: Product: USB4216 Smart Hub
[ 2532.200836] usb 1-1: Manufacturer: Microchip
[ 2532.201654] hub 1-1:1.0: USB hub found
[ 2532.202083] hub 1-1:1.0: 5 ports detected
[ 2532.487499] usb 1-1.5: new full-speed USB device number 11 using xhci_hcd
[ 2532.590384] usb 1-1.5: New USB device found, idVendor=3384, idProduct=0001, bcdDevice= 0.01
[ 2532.590388] usb 1-1.5: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 2532.590389] usb 1-1.5: Product: Launch Configurable Keyboard (launch_1)
[ 2532.590390] usb 1-1.5: Manufacturer: System76
[ 2532.600986] input: System76 Launch Configurable Keyboard (launch_1) as /devices/pci0000:00/0000:00:14.0/usb1/1-1/1-1.5/1-1.5:1.0/0003:3384:0001.000C/input/input27
[ 2532.661863] input: System76 Launch Configurable Keyboard (launch_1) System Control as /devices/pci0000:00/0000:00:14.0/usb1/1-1/1-1.5/1-1.5:1.2/0003:3384:0001.000E/input/input28
[ 2532.719609] input: System76 Launch Configurable Keyboard (launch_1) Consumer Control as /devices/pci0000:00/0000:00:14.0/usb1/1-1/1-1.5/1-1.5:1.2/0003:3384:0001.000E/input/input29
[ 2532.719669] input: System76 Launch Configurable Keyboard (launch_1) Keyboard as /devices/pci0000:00/0000:00:14.0/usb1/1-1/1-1.5/1-1.5:1.2/0003:3384:0001.000E/input/input30
[ 2558.786574] usb 1-1.2: SerialNumber: 20120331001
[ 3145.898068] usb 1-1.2: USB disconnect, device number 12
[ 5429.640377] usb 1-1.2: new high-speed USB device number 13 using xhci_hcd
[ 5429.800905] usb 1-1.2: New USB device found, idVendor=9588, idProduct=9899, bcdDevice= 0.00
[ 5429.800909] usb 1-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 5429.800910] usb 1-1.2: Product: USBLMCV2
[ 5429.800911] usb 1-1.2: Manufacturer: BJJCZ
[ 5429.800912] usb 1-1.2: SerialNumber: 20120331001
Seems to me that the device is being identified but that no driver is being loaded for it, thus no serial device creation.
I’m not familiar with the serial chip used on that laser. The vendor and device IDs don’t pull up any common information for me. I’m guessing this could be persuaded to load with an existing driver if the proper chip is identified.
Similar hacks using Zadig on the Windows side is sometimes used.
Can you check Windows Device Manager to see if you can get any clues about it?
Or perhaps anyone else who’s intimately familiar with this device may be able to chime in.
I don’t have any Windows computers. The mac identified and used it. I could probably plug it back into it and see what it’s using.
Sorry. Misremembered what you had said about that.
