Hi everyone,
I recently faced an issue with the LightBurn software where the UI text was too small to read on my high-resolution display.
After some troubleshooting I found a solution that worked perfectly. I’m sharing it here to help others who might encounter the same problem.
The problem is my high-resolution Windows screen. To be able to make everything on my PC more readable I have the layout scaling set to 200%.
However, when I opened LightBurn, the UI and text appeared extremely small and unreadable.
The solution for this problem requires some tweaking of Ligthburn.exe executable settings. These steps leverage Windows’ ability to handle DPI scaling on a per-application basis, ensuring that LightBurn’s interface is more readable on high-resolution displays.
Find the LightBurn application executable (
LightBurn.exe). This is usually located in the folder where you installed LightBurn, such asC:\Program Files\LightBurn. -
Right-click on the
LightBurn.exefile and selectProperties. > Go to theCompatibilitytab. > Click on theChange high DPI settingsbutton. -
In the window that opens, check the box labeled
Override high DPI scaling behavior. In the dropdown menu underScaling performed by:, selectSystem (Enhanced). -
Click
OKto close the DPI settings window. and ClickApplyand thenOKto close the Properties window. -
Lastly Restart LightBurn
I hope this helps anyone struggling with the same issue. Feel free to ask any questions if you need further assistance.
Best,
Keith
