Witam.
Mam kłopot z ustawieniami Lightburn.
Na podglądzie jest wszystko ok leczy po wypaleniu napisy są w lustrzanym odbiciu. Wiem że można to zmienić przed rozpoczęciem wypalane lecz ja chciałbym już mieć to ustawione (nie chcę pamiętać by za każdym razem to zmieniać)
Dziękuję
Hello.
I’m having trouble with my Lightburn settings.
Everything is ok in the preview, heals after burning the inscriptions are in a mirror image. I know it can be changed before firing but I would like to have it set (I don’t want to remember to change it every time)
Thank you
@joel1 is pointing you in the correct direction when they suggested, “Make sure the Lightburn origin matches the machine. Edit → device settings”
In the setup documentation we state:
Laser Origin and homing:
The origin setting is where the ‘zero’ point of your X & Y axis meet. If you get this wrong, you can change it later in the Device Settings page. This setting also controls the orientation of the output - if it’s wrong, the output from your laser may be mirrored or upside down.
If you have a GCode based controller, like GRBL, Smoothieware, or Marlin, commonly used with diode lasers or smaller hobby systems, in almost all cases the origin will be in the front-left. With GCode based systems, you are given the option to send the homing command when LightBurn first connects. If your laser does not have homing switches, leave this off.
