I’m using the latest release of the software.
In Settings, I have turned on ‘Snap to Objects’.
Lines are all on the same layer.
I’ve also tried highlighting all lines and to ‘Close Path’.
What am I doing wrong please?
If you zoom in very closely to the highlighted portions of the screenshot you will see that the node ends are not aligned. Select both line segments in node edit mode and join the ends. Repeat for each side.
Once corrected, select all line segments that make up the outline, then Edit->Auto-join selected shapes.
