Unable to radius corners in shape properties
I have a weird one. I cant radius the inside squares with shape properties. I ended up doing them with the radius tool. Outside square no problem. Did I miss a setting?
Shape properties.lbrn2 (4.6 KB)
It looks like somewhere along the line you converted the shape to path. Once that is done you can’t change the properties on the properties dialog. If you select the object and click edit nodes, you can edit the nodes. You can’t do that on a shape.
Weird I don’t remember doing that. Thanks for pointing that out.
