Hi Everyone,
I am new to laser cutting and still trying to work things out. I bought a 50W CO2 laser cutter to cut electronic enclosures for my business. I had success cutting my first enclosure at 60% power, 10mm/s (see photos). Cutting the second with the same settings did not come close to cutting through the (roughly 2.5mm thick) material. I then upped the power to 80% and ended up with a charred mess. Upon further tries I have been unable to cut through.
Does anyone have any clues as to what may have changed?
Hi Bernd, thanks for the input. I thought a similar thing, so I cleaned the mirrors and lenses, and checked alignment. Same result. Here’s where the head scratching really starts. I tried the same settings and pattern on a sheet of acrylic (see photos) and an ABS enclosure, and the results are perfect. When I back to trying to cut the original polycarbonate enclosure… still not cutting.
From what I’ve seen, thin polycarb sheets cut well, but anything more than a millimeter (-ish) doesn’t work. The lead illustration in that article seems to show a very thin molded form with laser-cut holes.
It may be a case of my 60 W laser not having enough mojo or the piddly assist air not having enough whoosh, but AFAICT 3 mm polycarb is on my “do not cut” list.
As you’ve probably already discovered, polycarb releases terrible fumes:
Thanks for the input. I ended up just engraving the centre point and drilling the holes with a step drill. It was surprisingly quick and easy with all the points marked.
Even though it’s an old post, I want to “update” my part of the PC experience.
I had to cut 3mm PC, a few items, a small order. - (privately I wouldn’t even touch that material with a fire tongs …)
The smell and smoke development were so intense that I feared for a while that someone would call the fire department. I could see thick smoke coming out of my industrial exhaust. Acrylic is not something laser toddlers should play with, but this PC is much worse.
The values ​​I used are 10mm/s and 45% power on my 60Watt (55…?) laser. The edges become rough and smaller holes tend to fuse together again, otherwise for very simple items…ok
It can be done, but if I ever have to laser cut PC again it will have to be at night with a lot of rain and lots of wind
