This is a new one for me, I have not upgraded to 1.0 yet.
I am creating paths (basic text files) in another drawing program (PlasmaCam 3.11) because I have it and have used it for 10+ years. It does a great job of creating DXF files. They show as being closed paths with no gaps prior to export.
Now when I import files, If I try to fill them, LB reports many unclosed paths have been ignored (In fact all of the paths are ignored. When I zoom in, it shows many segments with gaps, each can be selected No amount of welding selected paths, closing selected paths or grouping has been successful to close the path so I can raster fill the letters,
What am I doing wrong?
In the âeditâ pull down
Close path
In order to Fill a shape with your laser, the shape must be a closed loop, where the starting and ending point are the same. If the start and end points are very close, but not quite connected, âClose Pathâ will move them together. Click on âClose pathâ in the Edit menu or press Alt+C
Auto join selected shapes
Looks at the start and end points of all the selected curves, and if any of them are close enough, connects them together into a single shape. Useful when importing DXF files, which donât contain connectivity information. Click on âAuto join selected shapesâ in the Edit menu or press Alt+J
Optimize Selected Shapes
Attempts to fit the selected shapes to arcs and lines within a specified error tolerance. Useful for reducing the point count in a shape, or recovering arcs from software that exports them as many small line segments.
From Lightburn âMenuâ documentation.
Hope this helps
