Uneven Cutting on Work Surface
Good Morning!
I’ve had my Omtech 60 watt machine (first laser) for about 6 months, I’m finding that certain areas of my work surface either do not cut all of the way through or, they are really scorched.I’ve checked that the machine is level by measuring from the axis rails and I’m good. The lens and mirrors are clean. The tube was recently replaced because of TEM00 issues, so I only have about 200 hours on it.
So, while on YouTube, I saw some videos on air assist by Bearded Builds and others. I just installed 2 solenoid valves with a control valve on one of them for LP air, all fed from a remote compressor. I’ve set my regulator to 25psi (HP) and about half that on the LP. It works great no more scorching. But I’m having trouble cutting through 3mm Baltic birch. I tried turning down to 20 psi, and cutting got a little better but the scorching started returning. I’ve been running at 30% power and speed of 10mm/sec.
What’s going on?
Dale
Would you be able to give us a few visual aids on what you mean
Maybe some pictures of the engravs that faile
Also what areas on the bed tend to be the problem
Beam alignment CAN - not saying it is - but can cause problems like this
Where areas of the bed are perfect and others are compleatly wonky
Back left corner (0,0) has been the “hottest” spot. I’ll get some pictures this afternoon.
I had just checked my mirrors and they are good, I think.
Dale
If it is fairly ok plywood, I cut with 35-45% power and between 20 and 30 mm/s in speed with my 60watt OMT laser.
I always use air support, about 120l/min.
How do your test shots look at the mirrors and by test shots through the nozzle?. If the tube is ok it is usually alignment that is not 100% ok.
So closes to the Co2 tube if i got you right
Could really be alignment
Is a whole can of worms on which i would be not the best person to advise but sounds like mirror alignment to me
I’m sure you’re right. Every time I go through this with the mirrors I think it’s good, then…
I will try again
I also feel certain it’s the mirrors. Ever time I think I get it right, it turns out not right. I’ll try again.
Dale
Hey Berndt,
Thanks for the response. I checked my mirrors again. See the attached photo of M3 both spots near M! and the front right corner. I don’t like it! You will see a defined dot which was a pulse near M!. The shaded area a little up and right is the front right corner. I cannot get a good, clean mark in that position, just a blob. I tried at 10% power and got nothing. I moved to 12% and got this. This has been pretty much the case on pulses at the same position since Omtech replaced my tube over TEM00 issues.
Dale
what does this mean?
I suppose it’s on Miror 1 :wink:
As a starting point, it’s not bad, but when your laser starts at 12% then you need to reduce the pulse time ms, until you don’t burn in through. (It’s not so important at M2 and M3 But M1 should show you if your tube is OK.
In addition to that, I will work with fine tuning to hit the center perfectly. I know many who think it’s not so important to M1, I have a different meaning to it.
Yes, M1. I will up the pulse speed and try again. But I’m still bothered by the blob I get at the far front right.
Dale
Sorry, M1.
By the way, I saw one of your posts about a Russ Sadler Lens tube. Are these available to purchase?
Russ has produced a lot of neat goodies…
I bought a lot of parts directly from Russ… Incredible guy, don’t know where he finds the time to do what he does.
I doubt these tubes will work with the factory head you have, but I’m not an expert here…
Weights around 100 grams without the lens tube.
I didn’t really follow what you were saying here… I wonder about the marked target in this post. Is that 1 test shot or is it a far near… I assume it’s from m1, but you lost me.
An out of resonance tube or TEM modal issue can cause this… did you check that?
Both of these are a couple years old… remove the .txt extension
Lens Tubes, Lenses and Nozzles Chart.pdf.txt (30.0 KB)
ALL PARTS AND ASSEMBLY DIMENSIONS .dxf.txt (2.0 MB)
Have fun…
The target was on M3. The shots were back left near M1 and right front. The “blob” is right front. Speed 600, power 12%
It still needs to be tweaked to hit center or as close as you can on Mirror 1. Otherwise, by the time it hits Mirror 3, it won’t be able to vertically align correctly… Do you have a picture of Mirror 3 alignment tests? The blur on mirror 1 is normal but you should see a dot and the blur overlap each other. It’s hard to tell from the pic if that’s the case.
Check the tube for air assist and make sure it’s not clogged. Have you checked your lens?
Thanks, it was all of the above. It’s good now.
