I am trying to cut out a deck for an RC boat. I have designed the deck in Fusion 360 and exported it as DXF. I want to cut the inner hole and and mark where the glue the windows. See file below.
When selecting the window lines it also selects the hole lines. Is there any way to split these lines?
When you select any elements perhaps you know, but, if they are a group the moving lines that show whatās selected are a mix is tiny dots and lines. If itās a sole, whole element, they are even sized lines.
I hope this was relevant and helps
So each element needs itās own layer and designate the action you want there in the cut layer.
Have you tried the ābreak apartā in the āarrangeā tab?
select the red and blue parts, ābreak apartā then select the āblueā part by going 'right to left, you donāt have to catch it all as long as you cross the lines of the parts you want it will select it all then āgroupā
Break apart works for this, but it would be simpler to use Edit Nodes, hover the mouse over each corner in turn and press āBā to break the shape at that node.
Hover the mouse over the Edit Nodes button and press F1 for help to see the keys to use.
