In the units and grids section of the settings, there used to be a setting for inches, and one for millimeters, and then was one that was a combination of both. I can no longer find the combination setting. Does anyone know what happened to it? I hope it has not been removed. I am on version 2.0.03. Thanks!
There is a Settings window under Edit, and a Device Settings window under Laser Tools. Which one did you pick?
That’s in Device Settings where you set the Machine Units that can be different than the Design units applying to the Workspace grid.
If you use mixed length & speed units, always include the units when you describe your design & machine, because nobody will understand them otherwise.
Note that V 2.0 moved Device Settings to Laser Tools.
Thank you both. I was looking at the settings under the edit button. I found what I was looking for in the device settings. It is listed as inches / mm/sec.
