On a Mac.
Laser fires on adjust laser
I drew a test rectangle, when I click on Start laser trolly moves and is correct, Laser will not fire.
I find no real answer to anyone having this problem, at least not for my rig.
I should add that the Laser says it is ready
Type “$$” into the console and hit Return/Enter, then post what gets spit out here for review.
I changed Laser to this:
Laser works but: It won’t shut off when finished, I probably need to give it another command???
Also: Test Letter is backwards: Correction for that?
Note: image of portion of Console.
Just realized, the software (BenBox)which came with the Universal Engraver, is showing in Console. I am evidently not even accessing Lightburn’s software.HELP!!!
LightBurn does not support the benbox custom firmware. You will need to flash your board with GRBL 1.1f (or later) firmware first. I think you can use the benbox software to do this but am not familiar with the exact steps required.
