Unrecognized Board Signature: 0000809842402402
Wanted to Share my findings regarding this specific issue.
Laser is connected using USB Lite. (I have a 200x200 EMP Galvo Laser)
My Laser was throwing “Unrecognized Board Signature: 0000809842402402” with me for an entire day. Went through this forum and couldn’t find anything on this specific issue to help me out, hence this post.
Did all my checks and balances on the software itself. My Lightburn was active. All of my settings were as they should be. I switched to the most recent version (which is great by the way) to see if the outdated version was just buggy.
No matter what I did this laser was in and out of connection, didn’t recognize itself and kept switching from Framing to Throwing the Unrecognized Board Signature.
I finally started playing around with my USB and decided that it was only a couple week old and that couldn’t be the case. I ended up opening up my machine to bypass the internal USB. Luckily enough for me they have a Female USB port inside. I bypassed the Outer Female Port and plugged into the internal one.
Its been working perfectly fine for 3 days now, so Ive ordered a replacement and Life is well again.
Hope this helps.
Thanks for reporting Yet Another USB Cable Problem, particularly for an internal cable.
Everybody assumes the USB cable can’t possibly be the problem, so every bit of evidence helps.
Now, Fire The Laser! :grin:
On my fiber it worked great for about 2 years, then I had connection issues. I tracked it down to the USB jack on the controller.
Glad you found it.
:grinning_cat:
Thanks for sharing the solution with the USB cable!
Are you still seeing the “Unknown board signature” notice on connection?
It means that we haven’t seen this specific board before, so LightBurn doesn’t know what initialization is required for it. In this case, we default to using “USB Lite”, which is usually the correct choice and isn’t a problem.
Apparently, the message can also appear when there are USB connection problems
