Unwanted lines going to zero on the grid
this is hard to describe; while designing we used a lot of lines to create several grids/tables when we finished it looked good, then unexplainably all the ends of our lines continued to the zero-axis location. are our settings the issue
What does it show in the Preview window? Is this a new problem on an old project?
In the Cuts window, turn off the outputs one by one to see if anything unintended is left over.
What program are you using to produce your designs?
And how are you importing then into Lightburn?
