Can anyone tell me why I am getting these lines in the power scale I built in LightBurn. Just downloaded the latest version. This is the first time using this software, so I’m sure there are plenty of mistakes, please bear with me.
emphasized textt
You have not said which controller and firmware you use to drive this system and I do not see it listed in your forum profile. We should start with this.
I have a longmill 30x30 cnc and I added a Endurance 10w deluxe laser. I am using grbl. Hope this helps
If you are running grbl 1.1f or later, look at the $32 setting. It should be $32=1. Also check Edit > Device Settings and look for a value called ‘S-value max’. Make sure that matches your $30 firmware setting.
Here are the details for setting up with grbl gear: https://lightburnsoftware.github.io/NewDocs/CommonGrblSetups.html
And here is the documentation for the grbl firmware settings: https://github.com/gnea/grbl/wiki/Grbl-v1.1-Configuration
Thank you, I’ll try those tomorrow.
