Update 2.1.01 my Xtool laser does not go Home, Origin not working
Hello folks, after install of updates 2.0, 2.1, 2.1.01 my xTool D1 Pro 20w laser is not able to Go Home nor to Origin. I have loaded prior User Preferences and still does not work properly. I try to set an Origin to a specific location and the X & Y remain at X-0 & Y-0 location even though the laser is in the center of the work area. No matter where I place the laser module the location is x-0, y-0 and it thinks its in its Home position. I create a box and the laser frames at a different location each time. I will be very grateful for any and all help in figuring this one out. Thank you.
If you reinstall v1.7.08, does it go back to normal? No need to uninstall first.
This question has been asked about 20 times within the last week. There will be an update coming on Monday that should fix most issues with xTools hopefully. Though, if you use an xTool with LB and have a running setup - never do any updates! xTool is known to disable LB compatibility every time they can, so better not touch a running system.
There have been some changes with 2.1.xx for xTool devices - can you tell me if you’re using a GRBL device type or the newer xTool device type?
LightBurn 2.1.02 has some fixes specifically for xTool devices Download / Trial – LightBurn Software
