After thinking clearly for a while. I see the real problem. Under macOS short-cut keys shall be by using Command key in combination of one or more keys. Short-cuts with just Alt as a modifier should be considered text input and not a command.
I thought you got the $ by using the shift key? What has this to do with the Command and Alt keys? You normally just enter plain text in the Command window input box.
On a Swedish keyboard layout on macOS you get $ with Alt-4.
To make it compatible only shortcut keys should be with CMD pressed in combination with a key.
I know it’s cumbersome if it works, but does cmd-c / cmd-v work to copy/paste the $ symbol from another document? I am attempting to discern if the ascii character pastes into the Console window as expected.
